Martin_J
For something to do last night (as if I didn't have enough to do already) I was checking out the charging circuits on the Moody...
It has a one 12v engine battery and a bank of two (parallel connected identical 12v batteries) for domestic.
When I bought the boat I was told that the shorepower connected 3-stage charger would charge both engine and domestic. I was also told that the engine driven alternator would charge domestic only. This does appear to be the case and others I have talked to since have said that this is sometimes normal. It would mean that on a longer cruise when not connected to shorepower then engine battery would not get recharged - yikes!
Following the physical wiring last night I found that the alternator output is connected to the input (A) of a Sure Power 952 splitter. The outputs (numbered 1 and 2) are connected (1) to +ve on one domestic battery and the other (2) to the +ve on the other domestic battery. No wonder that only the domestics took the charge - both batteries being charged from the same place!!!
So - Do the experts think this is a case of mis-wiring... or is there any sound reason why the diode splitter outputs would be connected to two batteries that are in the same bank!!
I plan to move the second splitter output to the engine battery +ve unless I hear reasons for not doing this. Many thanks in advance.
PS - There is also an Adverc charge controller but I think this is irrelevant to the question.
