Andrew72
Hi everyone,
I've been looking at a few mid 90s, dutch steel mobos recently and wanted to ask your advice. Apologies in advance for a very long-winded post!
There's a Valk Super Falcon 45 in the Netherlands that needs TLC (probably a lot of it!) but it might be a good project.
https://drive.google.com/open?id=0Bzn74c1pofgFZVE0c3psN2Q5ZDg
All the photos I've taken of the boat are here ...
https://drive.google.com/folderview?id=0Bzn74c1pofgFTE9kcTlDRFpXNFE&usp=sharing
I've read lots of posts on the Mobo and Thames forums about dutch steel boats and what to look for / avoid (rusting bilges, etc.)
I'm considering putting in a cheeky offer (naturally subject to a full survey) but I wondered what the forum thought first.
Should I try to get this boat for a good price (-30%) or run away very quickly and look for something better?
The exterior seems pretty sound with the paintwork in good condition.
The main things that concern me are ...
- The engines
https://goo.gl/photos/RQkweyS4wf42uj3r6
2 x TAMD41B 150HP units with 1500 hours that were last serviced 4 years ago.
The boat has been up for sale for 2 years and I'm not sure it's been used in that time.
It needs new batteries.
It looks like there's been an oil spill (or is that explosion?!) in the engine room. My first thought is to avoid any mobo without a clean engine room.
It seems as though there's condensation over everything in the engine bay. Is that normal for a boat that's been sitting for 2 years? Or is there some, deeper problem?
I'm prepared to spend money overhauling the engines but I don't want to spend 1000s and 1000s if it's cheaper to buy a newer / better boat.
- The corrosion / staining in the bilges
https://goo.gl/photos/xoZbnJQW3e78g4418
I'm not sure exactly what's happened in the engine bay / bilges. It looks like part oil spill / part surface rust. It's difficult to tell at first glance whether the rust is really severe or if it looks worse because of the oil staining.
I'm understand that Valk boats are well built so should probably have been acid etch primed and epoxy painted from new.
Do the bilges look like they could be fixed with a really good clean, surface rust treatment and repaint? Or are they too far gone?
- Leaking hatch windows
The square window hatches (Lewmar?) above both bow and aft cabins are leaking and probably need renewing.
https://goo.gl/photos/ZYPKsyu8r1Sn6eMk7
Replacing the windows and the rotten wood around the window interior shouldn't be too big a job, should it? Would I need to replace all the headling in each cabin? The headliner "appears" to be in good condition throughout and, thankfully, in small panels so their easy to access or replace.
- Smell
I realise many, old and rarely used mobos can have a whiff about them but the smell on this boat seems to be mainly from the engine / bilges. The bilges are dry though. I think it's just the oil / surface rust that smells.
Clearly the boat needs a good airing, a thorough clean and new upholstery, carpets, etc. The smell seems to be mainly from the bilges / engine.
Access to the engine is via the stairs that lead from the saloon down to the aft cabin. The insutlation material underneath the stairs was very damp / soggy and probably a big part of the smell.
If I renewed all the insulation material and put a very good rubber seal on the stairs so it's water / air tight, surely that would keep any engine smells in the engine room?
I presume "sealing off" the stairs in this way wouldn't cause a problem for the engine? I guess it's getting enough air from vents and not relying on the small amount of air that might come in from the saloon via the stairs.
Thanks in advance for any advice you can give. Even if it's just telling me to wise up and look for another boat!
- The engines
- Smell
