qbot2
Hi All, This question is regarding removing rust and freeing rusted components, so I am unsure if this is a topic that you cover. I have looked in the FAQs and not found any clues. As background, I have a sailing boat (Hunter Sonata if that helps) with a swing keel mechanism. Basically, the swing keel is a large block of cast iron (1200mm horizontal/front to back x 400mm horizontal/side to side x 250mm vertical), with a slot (900mm x 300mm x 40mm). Imagine this (pictures are much easier!) being bolted to the underside of the boat, with the long (900mm) slot on the bottom, and open (300mm vertical x 40mm horizontal) to the rear. A 1200mm x 300mm x 38mm cast iron blade pivots on a 25mm dia bolt (at the closed end or front of the keel), and swings from horizontal (up or housed) to vertical (down or vertical) under its' own weight for sailing. The chap I have just bought the boat from said that the keel has been in it's UP position for about 3 years, afloat in a marina.
I now have the challenge of freeing off and removing the blade. So far I have cleared loose flakes of rust and debris from the slot with a pressure washer, removed the pivot bolt, attatched a winch to the rear of the blade to give a constant tension, used various hacksaw blades, improvised chisels and thin strips of steel to chip away at the rust build up between the blade and the slot. The blade has moved about 40mm with approx 9 hours work so far. I am just wondering if there are any tips or techniques you have, for ways to dissolve or remove the rust? I know that a number of products are available as 'Rust Remover', but I am not sure if they would penetrate the depth of rust in the slot or if the 'coating' some of them form on top of rust would jam the blade in further? Any Ideas? With the size of the keel block and the fact that the boat is fibreglass, I have not tried using heat...
Thankyou for taking the time to read this, if you got this far!, and I apologise for my long winded description, but I do not know what info you may need, to help me.
Cheers,
Austin Holden
Cheers,
Austin Holden
