They look like fairly simple fittings and I am suprised the bulbs do not just twist out. I have in the past resorted to a rather brutal resort of breaking glass with large pliers or similar and then gripping metal remains with long nose pliers pushed into 'element' part.
Just replace the fittings as suggested.
A lot to be said for that. I bought a 5 metre roll of 12v LED strip off eBay for not much money - I wouldn't use it for main cabin lighting as these particular LEDs are bit harsh, but it's great for lighting up odd corners as you can just slice a bit off the roll and wire it up. I have a piece running the length of my engine bay, and one of those cupboard door switches, so that when I open the engine bay doors the whole space is bathed with bright light. Since it's a long strip, my head doesn't cast a shadow on the very bit I'm trying to look at, as a single point source might.
Indeed the bulb holder feels like plastic, not metal that could be squeezed open and shut.
Thanks to all that have responded. pvb suggests pulling the bulb holder apart but prv is right, there is a curious layer of something that has stuck to the bulb. Indeed the bulb holder feels like plastic, not metal that could be squeezed open and shut. As ccscott49 and others suggest this is an exercise in changing to LED. The LED replacement is a bayonet with two wires and a board with nine lights. This gives me the option to reuse the existing fittings if they survive or to cut them away and wire directly without a fitting. The bulbs have their own protection.
I will start by being delicate, but be ready to resort to the pliers!
Thanks for all these useful contributions,
Doraymefa
Lighting strip is designed to be used with constant voltage LED drivers in domestic premises ashore, not on your boat where supply voltage can vary.
Actually quite a lot of it is sold for blinging up cars - I'm told the Chinese love that kind of thing.
And lots of lads here, but they write their Corsas off before the LEDs give up the ghost!
I'm sure that Chinese vendors do supply flexible LED strip for use in cars, I'm not really aware how long it actually lasts in a motor vehicle, or indeed, if, that type of strip is rated specially for use at 13.8 volts. I'm rather too ancient to bling up my own car so I don't have any experience in that area of lighting.Actually quite a lot of it is sold for blinging up cars - I'm told the Chinese love that kind of thing.
