pvb
Turnbuckles. Why do so many new boats have turnbuckles when it would be cheaper to use a bit of string?
Well, I've known pelican hooks fitted with 'locking rings', come adrift without outside assistance, which is not good, when you have a gap instead of a guard rail at an entry port.
The recovery crew in your scenario, would be back in the cockpit attending to the casualty, so safe from falling back in. Probably fell in in the first place, because of the bloody pelican hook.
String - on boat when I bought it so replaced immediately, now 11 yrs old so probably need replacing - polyester, so would it be a reasonable time to replace?
If one fears a lonely death adrift on the waters I'd suggest not going to sea.
.... If one fears a lonely death adrift on the waters I'd suggest not going to sea.
I personally use UHDPE for my guard rails - it's lighter, deals a lesser wound if one is thrown against it and is considerably stronger diameter against diameter of plastic-covered guard rail.
Even losing 50%strength, you'll still rip a stantion out of the deck before it breaks.
Bliimin phone! Deletes posts just to annoyUnfortunately, UV exposure rapidly reduces its strength to less than equivalent diameter plastic-covered wire.
That's the only thing I found as well, from here..Here's a graph I found online...
I think the bigger potential drawback of Dyneema guardrails is chafing where they go through the stanchions.
It is indeed 21st century.You might also like to ponder about U/V damage and salt crystal wear.
All metal with pelican hooks is surely the way to go, this is the 21st Century FFS !
We can now get lightweight nice on the hands rope which you simply can't break before something else on the boat breaks . Stick a pelican hook in if you want. You don't have to use steel wire rope anymore.
But why use rope? Strength for strength, it's bigger and more expensive than stainless 1x19. Unlike stainless, it suffers from UV degradation, and it's prone to chafing damage. It might be a bit lighter, but for a few metres of guardrail the difference won't be significant.
