johnalison
So long as it is not tighter than the forestay tension.It is not unusual to ease the halyard just before furling the jib, but that does not mean that one should not have a tighter halyard when the wind rises.
It's so strong it doesn't matter. We have been using a bowline for 36,000nm in our Dyneema 10mm halyard. Twice over its life we have shortened the line by 300mm. This is more about where the line goes over the mast sheave than an issue with a bowline. I never see the point of a spliced end or shackle in the main halyard. The bowline can be tied in sightly different location each time such that you move the chafe point slightlyJust remember you'll need enough to splice the end too, Dyneema and knots do not mix. E.g. a bowline in Marlow D12 reduces breaking load by about 70-80%
Rope Strength and How to Retain it - Marlow Ropes
A 10mm dyneema halyard is comfortably strong enough to pick your boat up with, so yeah, you don’t need that strength for a halyard. Dyneema for halyards is all about the stretch. Even with only 20% of it’s strength left, it’s still enough to rip the headboard out of your main.It's so strong it doesn't matter. We have been using a bowline for 36,000nm in our Dyneema 10mm halyard. Twice over its life we have shortened the line by 300mm. This is more about where the line goes over the mast sheave than an issue with a bowline. I never see the point of a spliced end or shackle in the main halyard. The bowline can be tied in sightly different location each time such that you move the chafe point slightly
Actually much more complicated than that..... a bowline in slippery D12 will just slip through before it gets anywhere near MBL. Just tried it, few hundred Kg it slips through quite gently with an occasional few millimeters "bump" .Just remember you'll need enough to splice the end too, Dyneema and knots do not mix. E.g. a bowline in Marlow D12 reduces breaking load by about 70-80%
Not much excuse for not splicing D12. It only takes a bit longer than a bowline.Actually much more complicated than that..... a bowline in slippery D12 will just slip through before it gets anywhere near MBL. Just tried it, few hundred Kg it slips through quite gently with an occasional few millimeters "bump" .
Agree, quick, tidy, crazy strong, can be made adjustable.Not much excuse for not splicing D12. It only takes a bit longer than a bowline.
Wrong stuff. We are talking cruising boat halyard. Use Marlow D2. Comes with a cover. It's still Marlow racing spec ropeActually much more complicated than that..... a bowline in slippery D12 will just slip through before it gets anywhere near MBL. Just tried it, few hundred Kg it slips through quite gently with an occasional few millimeters "bump" .
D12 is horrible to handle. We hoist our main by hand until the last 2 metres. D2 is far better for this.Agree, quick, tidy, crazy strong, can be made adjustable.
Knots will just slip out of uncovered dyneema.
Post was a response to some wrong info, not what to use!Wrong stuff. We are talking cruising boat halyard. Use Marlow D2. Comes with a cover. It's still Marlow racing spec rope
We only used D12 for standing rigging, like the bobstay, and side stays for the bowsprit. Our dyneema halyards are covered. We use it on the XOD for moving stuff, but generally on the non handled parts of a cascade. Immensely useful in the right applications, but it’s not the right rope for a cruising halyard, as you say. Even if you wear gloves, covered dyneema every time for a rope that is handled.D12 is horrible to handle. We hoist our main by hand until the last 2 metres. D2 is far better for this.
We have two sets of runners. One on the main mast and one on the mizzen mast. Both are D12. It's not nice handling that rope and we don't since they have normal rope on the pulley blocks. The D12 does chafe as well. I tie small string on to the mizzen runners to control them. They have gone wooly in the area where the string ties.
Thats the covered stuff. If it’s what the seller says it is, it’s perfect.
Be nice if the seller said what dyneema it is, maybe try a search for sk75 dyneema core?
Just be careful with ebay purchases of 'dyneema' I tried that once and got the stretchiest halyard on the planet. I only buy dyneema from reputable suppliers these days
a. You pretension a mast ladder (Mastmate?) HARD before climbing. Less bounce when climbing and less sway. If properly pretensioned, NO type of rope will stretch, including nylon. The ladder will not stretch if pretensioned (having used a Mastmate for 30 years). The pretension assures that.
b. Polyester can stretch after a hard sail, but if you tensioned it properly, only 1-2 inches. Something is wrong. Dyneema is nice, but you do not NEED Dyneema, not with polyester sails.
c. A polyester halyard should only stretch only about 0.3% under body weight (assuming no pretension, which is wrong), or about 2 inches on 50', If it stretched 20 inches something is slipping or there is something VERY wrong with the rope. Nylon climbing rope will stretch only about 1/2 that far, and nothing that would be used on a boat will stretch that far.
Something else is wrong.
Sorry thinwater missed your post. My ladder slides up the mast track so dont think pretension is necessary?
This is not my experience. I have had several polyester halyards with over 300mm of stretch on a 17.8 mast. The effect on sail trim is terrible. These are not new ropes needing their initial stretch. They are well used but now retired as I couldn't tolerate their terrible stretch. They were not used on jammers but had their own dedicated ST winch. No slipping. Just very stretchy rope. Dyneema is a game changer for me as a keen cruiserYes, considerable pretension. Certainly more than body weight. That is how you keep it from stretching with every step. If pretensioned, it cannot stretch due to body weight, because that stretch is already present.
Yup, lots of people trying to spend you money on Dyneema. For a cruising boat with polyester sails it is nice, but totally not needed, and polyester will last longer and handle better. I've have Kevlar, wire, polyester, and Dyneema. By all means change, but plyester is NOT the reason for the excessive stretch you are seeing.
Most likely the jammer is slipping.
Marking the rope will be a simple way to see if it is slipping. Easy.
- Rebuild. The cam teeth wear, and if it is original, they are not grabbing.
- Treat the rope. Moving the bite point is good. You might also try soaking some Maxijacket into the rope along the bit zone (~ 2 feet) to firm the rope.
- Wrong size. Is it possible the rope size has been changed and is now too small for the jammer? It will slip for sure.
Agree completely. Theres always a bit of stretch in polyester rope. It may not be much, but it will always manifest itself at a bad time. Just a few inches is enough to mess up your sail shape in a strong breeze, just when you’re trying to go to windward.This is not my experience. I have had several polyester halyards with over 300mm of stretch on a 17.8 mast. The effect on sail trim is terrible. These are not new ropes needing their initial stretch. They are well used but not retired as I couldn't tolerate their terrible stretch. They were not used on jammers but had their own dedicated ST winch. No slipping. Just very stretchy rope. Dyneema is a game changer for me as a keen cruiser
