mrplastic
I have a very strange problem...I have twin Volvo AQD40's one of which started overheating suddenly some months ago. It was originally diagnosed by a main dealer as an impeller breaking up...heat exchangers, oil coolers and all associated parts were removed, chemically cleaned etc etc. The whole caboodle re-assembled and viola....still overheating!! Now after further investigation it is definitely a raw sea-water. What happens is that when the engine is started the pump delivers a good flow at the discharge to the exhaust elbow....then for some strange reason and it seems at random....the pump just stops pumping. No water flow at the discharge into the elbow...nothing...bugger all...the pump shaft is turning (this can easily be seen through the aperture in the pump body). The impeller is brand new and in perfect condition, the splines on the pump shaft are perfectly ok...no blockages in the system.....has anyone else come across this problem? any solutions offered? all advice appreciated.
Thanks in advance
CLP
Thanks in advance
CLP
