Storing gas cylinders on board
CalicoJack
5 Jan 2004
Chatham, Kent
1) Ibelieve that gas cylinders must be kept upright when in use on board. ie you cannot lay them in their side and use them. True or false?
The reason for asking is that I have been watching on YouTube a series called Acorn to Arabella where the gas cylinder is clearly shown laying on its side. Arabella is a newly built/commissioned yacht in the USA. Safe or unsafe?
Daverw
2 Nov 2016
Humber
Could it be to keep gas vapour against the valve seals and they might not like be continually sat in liquid
You can store spare cylinders on their side, but the cylinder in use must be upright, or you'll get liquid gas coming through the regulator, and causing flare ups on the cooker.
Note that sometimes gas cylinders are liquid take off, eg for powering engines (forklift trucks often have gas engines). These cylinders tend to be used on their side. For normal boat use however, you need low pressure gas phase gas for the cooker, heater, water heater.
Plum
6 Jun 2001
UK East Coast
In the USA you can get cylinders of "liquified gas" or "compressed gas". If compressed gas then you can use any way up or on side. Liquified gas ones must be upright in use to ensure the outlet is above the level of the liquid.
Stemar
12 Sep 2001
Septics do things differently. Given the amount of research Steve has done, I'd be astonished if he'd got something so basic wrong. I also rather think he'd have found out about the error the first time he lit the gas.
lustyd
27 Jul 2010
Not this again! Forklift bottles have a tube in them and are marked as to which way up they must be mounted. All discussed and images shown recently on the forum. Gas Cylinder-Fuelled Fork Lift Trucks
Either way, the regulator doesn't have to be on the bottle. You could conceivably mount the bottle upside down and take liquid off somewhere else to evaporate and use. Whether that's sensible or not is a different question!
fisherman
2 Dec 2005
Far S. Cornwall
We were told in firefighting class that if a bottle on its side should leak it would be fluid, ie many times the volume of gas, and quickly fill the boat up. They use water powered fans to blow gas away.
There was a video of rioters somewhere in the far east, one holding a gas bottle upside down, the other lighting the gas. About twenty feet of flame.
