stiff throttles
ianainge
15 Jan 2003
Hampshire
I have 2x VP AD41Bs and notice that although she selects gear ok the second stage of operation ie throttle is very stiff initially and makes harbour and docking manourvous very difficult any ideas?
jfm
Jersey/Antibes
You need to identify what's causing it. (a) throttle box on dash (b) cables or (c) something in the engine. 99% of the time it's the cables, so grease/exercise them, or replace (they're cheap). In your case, it sounds like the throttle cable - the morse lever mechanics on the dash seem ok because the first part of the travel (ie the gear select) is ok.
ccscott49
7 Sep 2001
Just a thought, but are both stiff? If so it might be something else, I would disconnect the throttle cables from the engine, then check them again, if they are still stiff, then I'd discoonnect them at the control end and move them by hand, if they are still stiff, bin 'em! If ok then it's got to be the controls, simple innit'!
