Bigplumbs
This is applicable to Ultraflex or Teleflex steering.
Last year the steering on my little Rib got quite stiff and surprise surprise now it is seized altogether. Here is my method of fixing it. It is almost always dried grease crud in the tilt tube and seldom the actual outboard pivot itself.
The golden rules are:
1) Try not to let it get seized as I did.... Do this once it starts getting stiff
2) Never use thick grease
3) If you do use the grease nipples to grease (which I would not advise) then make sure the steering cable is retracted so as not to force grease between the inner and outer.
Here is a little video of how to fix this situation..... It is a messy job but someone gotta do it.
