simonfraser
'Are you saying that they cleaned it and tested it to find no faults? '
correct, bosch clean it before they test it and found no faults on the pump
will clean the circular connector, i had a grey OEM connector which was v suspect and eventually faulty, removed that and soldered it
obviously can not do that with the circular one as the pump is def a removable item
any one had probs with this connector as in wires disconnecting from the pins, or 'just' contamination ?
