Sticking keys
DavidonMersea
14 Mar 2021
A couple of keys on my lappy are sticking. I had this problem with a previous lappy long ago and I mention if on here, and I was given a lot of useful advice. However, I cannot now find this post, so what is the latest was to free sticking laappy keys?
D
Deleted member 478
1: Turn your laptop up-side-down then tap it gently. All the crumbs from your sarnies should fall out.
2: Don't eat the crumbs because they're definitely stale by now
Or run the vacuum cleaner over your keyboard (be gentle)
Daydream believer
6 Oct 2012
Southminster, essex
One of our site managers had sticky keys, so the labourer hoovered his laptop when he was out. When he came back the "W" was missing. Lots of hilarity about not being able to insult staff anymore, but key was found in hoover dust.
On a more serious note--I had a problem with my keyboard on my last Dell laptop & bought a new keyboard. This was basically a sheet of keys in a thin frame. It was not expensive & fairly easy to replace. The old one had started to be a problem, due to minute pieces of grit falling into the keys, which simple cleaning did not remove. My latest one is built differently; but you may have one with a key pad layout that can be prized off & if so it is a good fix.
You can buy a pressurised aerosal can which you can use to blow air in around the keys to help remove grit. I have not tried this option.
davidej
17 Nov 2004
West Mersea. north Essex
I spilt some drink on mine. When I cleaned and dried it out, the keys often did not produce the symbol shown on the key.
A new board was under £20 and YouTube gave fitting instructions.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
One has to be careful when searching the vacuum cleaner dust after cleaning sticky keys:
From bmj.com/content
"Penile injuries from vacuum cleaners"...
