PCUK
Fitting a small keel or skeg right under the transom just ahead of the outdrive will dramatically improve slow speed manoeuvring as it acts as a fixed rudder. I have fitted them on several boats, just bolting through the hull into a plate inside. All made of mild steel and epoxy coated, so very cheap! They have no adverse effect on high speed running and also help to protect the outdrive from impact damage. Far cheaper than a stern thruster but I seem to be the only one in the UK to regularly use this method of improving outdrive handling!
