misterjenkins
Following an incident where our stern tube and prop shaft were bent whilst being lifted by the marina, I wanted to get some thoughts about the repair.
The engineer the marina asked to do the repair initially said that our stern tube needed replacing. We visited the boat today to look at the work done. Having been unable to remove the stern tube (it's bonded directly into the GRP - she's from the early 70's ), they have cut away the damaged end, fitted a sleeve and a new section to the end of the tube, rather than replacing the entire tube.
Is this an acceptable repair? The engineer and the marina are adamant that this is better than what was there before, but we're not so sure.
Would welcome your thoughts.
Photos below show the original bent tube and prop shaft, and the new tube and sleeve fitted.
