merjan
That makes sense. I suspected that, but having managed to screw the new bearing into place I assumed it was all good. It might be the cutless bearing being too tight. I hope the shaft will eat away some of the rubber and it will sort itself out with time.Drifting an 1,5 inch deformed 1.4 inch hold will not totally make the deformed hole trully round as any metal needs over bending so it remains in the required position.
I would get an 1.5 inch reamer to ensure the hole is the correct size and trully round.
The other way is to reduce the o/d of the cutless bush and fit it with epoxy to ensure it is concentric by fitting the shaft before the eoxy sets fully
How do you get the cutless bearing out again if you fit it using epoxy?
