Boh999
Hi!
Asking here as Sterling products are not so common in Sweden so our native forums are rather useless.
Alternator -> Sterling Alternator to Battery Charger 80 A.
Sterling AB has two outputs:
1. START bank
2. LEISURE bank
1. START bank goes to
Victron Argofet 200-3 splitter.
I connected minus to the ground on it. It is this one:
https://www.victronenergy.se/upload...olators-with-alternator-energize-input-EN.pdf
Output 1 goes to START battery bank
Output 2 goes to RESERVE START battery bank
Output 3 goes to WINDLASS battery bank
Regardless, there should be current going to the Victron and on each of the three cables from Victron to the banks. These are all plus cables.
When AB starts, it charges around 7 A on the cable from AB output 1 to Victron, while doing its boot sequence stuff. After 30-45 secs it stops charging on output 1.
Victron also has a plus input to connect to and feed alternator B+ (to make it work) but see no reason as both alternator and solenoid are working?
2. LEISURE bank goes to LiFePO4 bank. I replaced an AGM bank with this, so changed to rotary switch to "9". When starting the AB (happens when it gets current on the input) it shows this as setting 4 "Euro GEL". Is this correct?
It charges the LiFePO4 bank ok, via BMS of course so seems to work pretty much ok, just curious about those LEDs, just the first four being lit.
Previously, with the AGM bank, I had the plus voltage sensor from Sterling connected to plus on that bank, and the minus voltage sensor connected to the AGM minus. However it is ambigously stated in the Sterling manual that no temperature compensation is necessary with setting 9 = LiFePO4? I removed the minus temperature sensor from the LiFePO4 bank. The plus voltage sensor is still connected to the LiFePO4 bank plus side. Is that correct? Doesn't say in the manual.
Cheers and thanks!
1. START bank
2. LEISURE bank
Cheers and thanks!
