Overandunder
Active Member
Wow - thanks for the tip, that's a worrying picture. Presumably Jeanneau didn't think fixings along the forward edge of the bow (GRP stem) were needed ?? I will check the deck join at the bow tomorrow for any cracking / signs of movement.Unfortunately, I have first hand experience of this fitting as I have a SO 29.2. When I bought it 4 years ago I had new rigging fitted as the mast was down. The rigger tensioned (quite hard) the rig and left the forestay in the forward hole as it always had been.
At the end of that year the yard owner noticed my forestay/ anchor roller fitting was lifting off the deck.
If you look at the photos the forward hole is well forward of the 3 mounting bolts so the forestay tension is trying to lever the fitting off the deck which is what happened in my case.
Anyway an amount of glassfibre work and a new fitting were done and the forestay is now in the aft hole.
The fitting cost about £1300 from Jeanneau!
Apparently the dealer has sold a number of these fittings.View attachment 183124
