Conachair
Guest
I have an Ebbtide 33' steel cutter which I had lifted out of the water last week. In Feb I had her lifted out in the Medway, lots large bubbles in the paint down one side down to the steel. A guy in the boatyard straight away asked if I had been tied up near an old wooden boat, which was the case. He said that the copper nails in the timber attack the steel. This all seemed to make sense as that was the side of the hull which was next the a decrepid old timber thing for a many months. When I got lifted out the other day I had the same problem in the same areas. Between then and now the boat has beed sailed from London to Portugal, very rarely on shore power and if so just into sterling charger which supposes to have no direct earth connection. In Feb I used an angle grinder to grind back to metal and gave it 2 or 3 coats of VC tar epoxy.
Any ideas whats happening? Could it be that paint was badly applied? LX wise I usually only have the lighting circuits on. Meter which goes down to 0.1a show zero draw when lights turned off.
All help much appreciated.
Ta
Ta
