bricklin
Active Member
[/QUOTE][QUOTE="Bouba, post: 7704805, member: 164226"it would be very difficult to view .
Guy who painted it reckons moisture has got in behind during project
Looks like a temporary fix up is all l can do.
I’m at a loss on what filler to use !
It could be rust under the paint. If it’s just surface rust then you should see it if you scrape some of the paint off. Is it possible to look at the inside of the hull in the bad spots to see if there is rust all through ?
