Poecheng
The water taken from a bucket is not under pressure - the water pump sucks up what it wants. The OP stuck the hose pipe itself (ie under mains pressure) up the inlet and therefore the water remained under pressure and water flowed into the engine regardless, filling the exhaust up and working its way backwards into the cylinders.I don't understand what went wrong. I have often run the engine ashore but I put the intake into a bucket that was being fed by a hosepipe. The engine then pulls in what it needs, however the water cooling system is separate from the cylinders, so don't see how it caused a hydraulic lock?.
That is my understanding
