Wansworth
Is it ok to star an outboard out the water.The reason I ask is it might be easier to pull the starting cord whilst the engine is hoisted up out the water .
No. You will trash the water pump impeller if you run it dry.Is it ok to star an outboard out the water.The reason I ask is it might be easier to pull the starting cord whilst the engine is hoisted up out the water .
No. It needs a wate supply. A dustbin full of water or a pair of theseIs it ok to star an outboard out the water.The reason I ask is it might be easier to pull the starting cord whilst the engine is hoisted up out the water .
Ok,thanksNo. You will trash the water pump impeller if you run it dry.
My outboard is the "sail" version. It has a simple rope guide which allows a vertical pull.Ok,thanks
I've never heard of one of those. Do you have a link for it please?My outboard is the "sail" version. It has a simple rope guide which allows a vertical pull.
O my Dufour the engine raises and lowers vertically,if I cannot get a good pulling angle I will see how quick I can get it into the waterI've done it in the past when I had a Seagull on back of the Alacrity ... no way I could start that when lowered ... and did it occasionally when my Mercury was reluctant on the Snapdragon 23 ... but I made sure I could drop them down FAST once they fired up ..
But my later outboard boats have fixed mounts - so engine is tilted to raise prop from water .. then as I said before - the carb is then at an angle and unlikely to work .. pull cord would be at terrible angle anyway.
Not link but a photoI've never heard of one of those. Do you have a link for it please?
