kacecar
My boat has just been re-launched after a year on-shore "fixing" various things and the time has come to start, or rather re-start, the engine. The engine, a raw-water cooled VP2003 (yes it's old, but it has always been well looked after), was working perfectly before it was taken out and, beyond some protective measures and normal maintenance items, did not require or receive great attention while out of the boat. Subsequent re-installation proved straightforward. As far as I know, all connections have been re-made successfully, without incident / issue (by me, rather than by a professional).
Now, back in the water, it is time to start it but the cranking speed is low and the engine is refusing to start, even to cough, or splutter. Up until taking it out of the water last year, and since I've had the boat (16 years), the engine has started reliably and after very few revolutions - but not now.
The batteries (3) aren't new (two years old) but have themselves been maintained over the last year and appear capable of taking a full charge. Putting an extra battery (a big jump start pack) into the circuit (at the batterypoint rather than direct to the starter - direct connection requires a separate cable) has no apparent effect. I've dismantled, cleaned and re-assembled all the connections, from battery to block, that were disturbed during the engine removal and installation process. There appears to be plenty of fuel at the injectors.
I suspected starter-motor but cranking while the engine is "de-compressed" produces the anticipated increase in revs (although, it might still be turning slower than should be expected - I'm not sure) and I wouldn't expect starter-motor performance to degrade just by standing for a year in a proteced environment.
I'm planning to make up a cable so I can attach a battery directly to the starter motor and try that, but I can't do that today so, in the meantime, I thought I'd ask the forum. Any ideas as to what might wrong and/or what to look at next? All suggestions / thoughts will be gratefully received.
