Starter Solenoid/Regulator Problems
TonyTitch
12 Nov 2001
My SABB HG inboard diesel has a Bosch Dynastart (combined starter motor and dynamo) for starting and charging, controlled via a Bosch starter solenoid/regulator. The latter sometimes only operates when given a good whack, despite a good clean up of the contacts, WD40, etc and may be at the end of its life. A replacement from Bosch costs £247, but I have heard that an equally suitable unit is fitted to a car and costs about £20. Does anyone know if this is so, and if it is, which car. Thanks
I have the same system on a Volvo. I know this used to be common as I used to run vintage bikes but havent heard of it on anything post about 1950's though others might have. I am looking at designing a solid state alternative, are you interested in sharing ideas on this?
Roly, Voya Con Dios, Glasson, Lancaster
chippie
21 Aug 2001
Northland New Zealand
The solid state alternative would work for the regulator but not for the solenoid as it is an electromechanical device.
I have a sachs rotary engine that has a similar setup and has had the regulator adapted from a car. Any competent auto electrician should be able to sketch a wiring diagram. My one doesnt have a solenoid attached as it is engaged via a drive belt. If the problem is in the solenoid sometimes a strip down and good clean out can wok wonders if the solenoid is still electrically sound.
Cheers.
toad
31 Jul 2001
ESSEX ENGLAND
I have not heard of one fitted to a car but bought a new bosch unit about five years ago for about £70 from a alternator/starter recoditioner,it sounds like the £247 inc the marine mark up.
philip_stevens
live near Saint Ives, Cornwall.
www.celticwebdesign.net
I would suggest that whatever else you do, don't, repeat, don't use WD40 on anything electrical. Once the solvent has evaporated, it leaves a sticky troublesome residue. It is best as a metal protector, but not on moving electrical parts or contacts. For contacts get an electrical solvent cleaner only.
Many moons ago, when I was in the Fleet Air Arm, Rocket/WD40 (as it was then called) was the be-all-to-end-all. It was sprayed into the elecronics/radio bay of helicopters. These went hovering over fields, collecting dust. Next over the sea, collecting spray. Result - short circuit faults. Its use was abandoned and only used to seal the skin of the helo - keeping moisture out of the airframe.
regards,
Philip
[448]
3 Oct 2001
I had similar trouble on a Vire engine. I cured this by fitting a Lucas alternator (£5 from a scrapyard) into the existing drive belt setup, and scrapping the charging side of the dynastart. This worked beautifully and had the benefit of a much better charging rate. If the solenoid side of the regulator is u/s you could incorporate an independant solenoid from say a Mini and totally bypass the Bosch unit.
Cheers, Dave
