Standing rigging 20 years old
The surveyor on our boat purchase last year said that the if the rigging is 10-20 years old it is likely to last until the same point as if it was replaced with some new rigging today, as the stainless steel of the new stuff is not as good quality as the older stuff.
I agree that manufacture has paired specs back to near minimum on many products in todays world .. but the specs on such wire etc is tight and should not cause concern.
Interesting that the rigger says "strongly recommend" and you interpret that as "should be replaced".
This seems to be the general trend, recommendations that may be a cover your arse statement by the surveyor are taken as a must do by the survey commissioner / insurance company.
Surely, if the surveyor finds something wrong or worn to a point that it is likely to fail, he should say so and say "should be replaced" and give reasons why.
No arguments here but the insurers, GJW, state that compliance with the surveyor's recommendation is a condition of cover. I'm pretty sure that surveyors' reports are based on a template with some of the details changed for the particular boat and a lot of the "recommendations" come as standard.
I have Surveyors and Superintendents in many different countries doing many different jobs. One of the biggest headaches I have : Because of Computers - I see modified old reports being used again and again ...
I have strict instructions to them to not do this .... but of course it does.
As regards this rigging item ... as I said before - its an item that due to its being mentioned so often as a 'cover arse' comment - it has become a standard item in many Yacht Surveyors reports.
lots of advice for and against, my view is I wouldn't want wires holding up my mast that have been doing that job for over 20 years. Replacement is such a simple task.
OK so it seems replacement for you is a simple task. Buy the boat and change it if it makes you feel better. I don't see the issue.
I wouldn't be changing it if it was me unless there was some other evidence it had been damaged or was in poor condition which would be flagged up on inspection or survey or you could see yourself. If you can make and change your own rigging then surely you are capable of self inspection.
My rigging is13yrs old. I do a visual inspection of wires and all terminals each year. Spoke with my insurance company when it was 10 yrs old. They weren't bothered. Didn't need a survey to continue normal full cover. 10 years limit is a maritime myth in my opinion and personal experience. Some insurance companies may have reportedly used it to wriggle out of claims in the past but if you have the conversation with them when taking cover, there's no wriggle room.
Tiderace quote :- If the standing rigging is wire, I doubt you will find anybody who will insure your rig. I cant recall the relevant standard; but it is most defiantly 10 years replacement or survey (which can be similar cost to replacement). Rod is a different matter. Insurance companies will ask on this and will want a copy of the survey report.
There is definitely no limit as you state or I and many thousand others would not have insurance cover.
My acceptance letter from GJW in 2002 stated
"We warrant that the recommendations are carried out as stipulated by the surveyor."
The recommendations included renewal of standing rigging, a new gas installation, new fire extinguishers, et al.
Thanks for the advice.
But my op was about negotiate I price taking into account the old rigging
Most Yacht surveyors are not riggers. I've not met one yet that would even think about going aloft to have a look. I've seen them using binoculars though. :)
I would have them put a statement in the report that the rigging was not inspected and would be subject to a seperate rigging survey. That way you avoid the stupid cover your arse statement they cut and paste into the reports. Then get a survey done by a good rigger and explain that you are not in the business of changing for changing sake, you need a thorough inspection and report that lists any deficiencies and the action required to remedy. Then complete the work he stipulates is necessary. A conversation and good relationship with the rigger helps you understand the why's and wherefore's of his findings.
Yes I saw that the original post was about you using the replacement rigging cost to reduce the price but the thread has moved on since then and has gone into survey requirements for insurance purposes and the quality of the average surveyor report for insurance purpose. So I was partly commenting on that as well as your original question.
I guess the difference between you and me is that I've had my rigging from new and know where it's been and what its done. Your's is an unknown to you. As I said, if it makes you feel better then change it.
I think the sale has fallen through anyway. Not because of the rigging issue.
Fearing a backlash ...
I d admit that after a number of seasons - I let insurance lapse and since have not bothered. There is no requirement over here to have any even if I moor at the local club.
Remind us all exactly where you are happily sailing with no insurance cover so we can avoid bumping into you?.
Bit risky with no third party or wreck recovery??
Is your home worth anything to you?
Don't we all love this debate - it goes to the heart of how much confidence we have in our vessels not to crap out on passage, and that spreads the topic to engines, controls electronics et al. As for personal ability to cope with conditions, we'll leave that for another day.
The chances of each critical item failing on passage are core. The engine is perhaps the most likely to stop, and the rigging the least likely to fail. I replaced my SS rig at 15 years, boat owned from new, as a precaution, taking the view that in my ownership of perhaps 25 years before sale I would have spent just £1200 on the materials, plus yard costs lowering and raising the mast = £1500 = amortised at £60 each year over 25 years. I consider that reasonable for peace of mind, and the record will show the prospective next owner I took care of the boat. My insurer takes the view that a special rig survey is not required, even over 20 years of boat age and that seems to confirm their experience that rig failure has a low probability.
When it comes to buying a used vessel, if no proof is offered that the rig has been renewed for, say, 15 years, and you intend to keep it for a few seasons, this is probably a good investment; how it is negotiated into the vessel purchase price is secondary, but it is a good line of argument for a discount if the asking price is a full one. If this is the only core concern, proceeding with the purchase seems reasonable. As we all know surveyors will guarantee nothing as to the status of the rig, or anything else, won't ascend the mast to check out tangs etc, so there's no recourse there.
That's it.
Good luck
PWG
For years I was a Newton Crum client ... sensible (for UK !! - UK is more expensive than most countries I have checked) premium. They were famous for paying out after the UK Hurricane - while other well known Ins were arguing.
My Snapdragon while moored at Farlington, was broken into and literally stripped inside ... sails ... fishing gear ... even to smashing the internal door ... NC were good .. we agreed a solution to replace all sails and any gear that was not covered - House Contents (L&G) covered.
Couple of months later - the forestay ripped out of the stem and boat was damaged getting back into Bembridge. This is where things took a turn ...
Unknown to me till I received a refusal of my claim - NC sent a Surveyor to IoW to check over the boat because it was soon after the first claim. The report written by that Surveyor was the biggest load of rubbish I have ever read. I'm a surveyor and I would be ashamed of such a document.
Basically his instructions as I found out - were to investigate the PREVIOUS claim and see where I may have falsified. His report made claim that my boat could not have had so many different sails as previous claim stated ... that the internal door and forward hatch had no signs of forced entry ... they are just examples. The fact the boat when broken into had Hanked on foresails and not the Profurl NC and I had agreed was a cheaper alternative to all the sails I had stolen - he missed completely. The internal door and hatch had been cleanly repaired and faired back in.
I actually spoke with the Surveyor ... Boatyard gave me his contact details. He was shocked as he was not expecting me to know who he was !! NC then received legal notice regarding their actions. The surveyor was informed that it was under consideration to add him to the 'notice'. No permission had been given for his access and entry into the boat. Boatyard was after this given explicit instructions that no-one other than myself or yard person had any access to the boat.
NC then washed their hands of it all and referred me to the Underwriters direct.
Underwriters and I came to compromise solution in that they 'wrote off' the boat, paid me market value and I retained ownership ... originally they stated they would pay and keep the boat themselves. I reminded them that Yard fees were mounting, boat was damaged and they would then have obligation to solve. They quickly offered me to retain the boat ...
The boat was repaired, in fact she was better after as the standard Snapdragon forestay attachment was the reason for the event ... being a simple nut and washer under deck set into the GRP of the stem. We replaced that with a better blade fitting and also bar extending down the stem .. but returned her to hanked on sails ... I sold the Profurl to Westerly Tiger owner.
Later I heard that NC had closed down and it was some time later I heard they had started up again possibly under new management.
OK - its a bloody horror story - BUT the fact is NC did honour claim and no mention or quibbles about age of sails etc. The second claim was paid out on Underwriters direction - again no mention or quibble about age of rigging.
Lets move on ... my next boat was 3rd Party only via Basic Boat ... purely to satisfy Marina requirement for Salvage / Recovery coverage in event of sinking alongside.
When the boat moved to Latvia - and to my own private moorings - I wanted Insurance for the Baltic Cruises - and Mannheimer AG was advised by a friend in Riga who deals as a broker. Mannheimer were excellent with significantly better and cheaper Insurance than any quote I ever had in UK. No surveys - just a letter from me stating general condition, intended use etc.
They had literally no limit on geographic location of the boat or its flag.
Sorry to veer of on a tangent .... but maybe it helps someone. If anyone has trouble with a claim and Broker doesn't 'live up' to expectation ... DEMAND access to the REAL insurer - the Underwriter. They will not talk with you - they insist on Letter ... Fax or Email only. But that is the ultimate decider - NOT the Broker.
Thanks for the detailed reply. I had an issue with a surveyor appointed by anchorage marine(Australia) My boat was damaged in the Queensland flood. We lost our dinghy and the hull was damaged both sides The boat had just been repainted the year before so was in good condition. They sent the surveyor to try and and find some sort of loop hole to avoid paying the insurance. What was funny was the boat yard i had my mooring with was approached by this surveyor to ask if i was trust worthy etc. He approached the secretary at the yard and started asking about the paint work and saying it was not a good paint job, trying to work an angle to reduce the fee for the new paint job. He then asked her if i was trustworthy and the sort of person who might make a false claim. I had lost my chain and rocna anchor. Another yacht had dragged on to my boat and had used bolt cutters to free his boat by cutting my chain. Nothing i could do about that! My dinghy was lost (Walker Bay) as it was on a friends boat that sunk in the floods. His kids were using it as it had the sailing kit. So he then approached the manager to say the original paint job was not very good so maybe i was trying to get a new paint job.(By the way the paint job was superb) He had made an assumption that because i was English the boat had been painted elsewhere. By that time the boat was on the slip so the manager took him out to the boat and said that the paint job was good. The boat was scratched down both sides along the entire length. The manager then went and got all the paperwork for the paint job as that yard had done it. So he climbed back into his shell. But the best was to come. My wife was the secretary whom he had approached in the first place. We got a full paint job and about 50 % cover on the dinghy plus new chain and rocna. About 3 months after the pay out my dinghy was recovered and returned to me. It was barnacle encrusted and cleaned up with jet spray. I rang the insurance people and told them and they asked for the money for the dinghy returned. I said no and never heard from them again. I changed insurance companies.
Further to my post my recovered walker bay. The surveyor did not believe i had a walker bay but fortunately there was plenty of paperwork from purchase to even a photo of it on my friends boat as well as us using it.
When I bought my Sunrider 25 ... guy selling gave me his copy of the Survey carried a year or so earlier ............... I laughed and he asked why .....
I answered that now I knew why he had advertised it as Colvic .... which had caught my attention ... as I always liked the Colvic 26.
The daft surveyor had written it up as a Colvic 26 ... this was no typing error or use of old report as it was still Amstrad days !! A 286 PC was a dream machine !!
The boat had no connection to Colvic at all, not even the belief that it was the basis of the Colvic design .. It was from Searider Yachts of Poole. They produced Seariders and Sunriders on the same work boat hull moulded by Tylers in Essex. Possibly the mix-up came because Colvic CRaft were also in Essex.
Look at that Genny ... UGH !! if the wind gets up - he'll wish it was half the size !
We had a list of good and bad surveyors. If you got one for insurance purposes to re insure your boat you got a lazy one. Just had a quick look charged you too much and then wrote a suitable report for the surveyor.
Been there - got the T shirt. I really disliked some of the guys who put themselves up as yacht surveyors .. charlatans ... and the Association was not much better .. had a few run ins with them ... in fact I advised one client to sue them.
Very glad to be out of that market now ...
