Standard horizon radio
Cavalierbond
26 Jun 2018
Have a quest x 1500 ge … comes up with low power like it ruining out of battery ..
thing is all other plotters etc work ok .. new batteries and charger etc. ..
is it knackered ??
You might measure voltage at the radio connector and compare to the battery voltage. A drop would make drawing a new wire and cleaning all points feasible. Check positive and ground separately to find the weak wire and/or points
Some times you'll even be able to pull the new wire through by connecting it safely to the old one then pull carefully ;)
Was a corroded connection deep behind the dash board ..
Thanks for you reply’s .. saved me buying a new radio and being back to Sq 1
