Chris.mcc240
I have the following set up on my centaur.
A standard horizon CP180i with internal GPS linked to a standard horizon radio with DSC not sure of the model “although it’s new ish” without being on my boat but it doesn’t have an AIS display. This I have linked up to a Simrad TP22 tiller pilot and it works well so I must have connected it all up correctly.
As I sail single handed sometimes I have decided I would like an AIS display. I came to this conclusion last year off the east coast in the dark surrounded by a dozen different ships.
What do I need and can anyone recommend a supplier?
I have the following considerations
Is it best to have the display on my chart plotter or will this be too much info on the 5 inch screen I find it a little cluttered sometimes now, but being in the cockpit its really handy.
Option 1 AIS engine
To do this I believe I need to use the signal from my VHF Ariel which is mast mounted but will need a splitter and an AIS engine, which will need to be compatible with my set up . Do I need anything else?
Option 2 AIS DSC radio
Change the radio for one with built in AIS. I assume I will only need one Ariel input so will save on the splitter and won’t need an AIS engine. I’ve seen a standard Horizon GX2100 but will this or any other unit overlay the AIS display on my CP180i chart plotter.
Has anyone else got a similar set up with the same chart plotter?
Option 2 seems cheaper and much simpler to connect with the option of being able to call ships direct. But is the NMEA wiring going to be the same as the radio I installed last year.
I’m sure I could ask a marine chandlers the above but I would like unbiased advice.
Option 1 AIS engine
