We are delighted with both our stainless steel chain(which does as jfm says flow like cream) and our Ultra SS anchor.
60m of 10mm will look tiny compared to 80m of 12mm! I hope you have a big chain locker.
Apologies to Magnum for the thread drift. SammyB does that snubber stay attached to the chain whilst you deploy it even if you don't have tension on the rope(s)? The reason I ask is that we have a similar looking Osculati snubber and its a bit of PITA because you have to keep tension on the ropes as you deploy it otherwise it just falls off the chain so, effectively, deploying it is a 2 person jobWe also have the Ultra snubber which is great to both deploy and retrieve.
Neeves, I have zero interest to restart the debate on this matter that was already done to death in Hurricane thread on his anchoring upgrade, but for the records, I can't recall anyone to have called your suggestion (let alone yourself!) stupid.Finally use a snubber. This will take the load off the windlass and thus neither damage the windlass nor deck - in a blow. Ideally the snubber needs to be really long, 30', as it then also protects the chain - but I know you MoBo owners think this is stupid.
Yup. And not OTT in any complimentary sense. Where Magnum will be boating, if the wind gets that strong he will want to get the hell out, not stay put. His wife may well be attending to a <1 yr old baby. The last thing he wants when retrieving an anchor in an unexpected strong wind is to be faffing and tangling a snubber, when a simple press of a button will retrieve the anchor if there is no snubber. I never use a snubber, and doubt I ever will, for exactly this reason: in a storm I don't want to stay anchored, I want to get underway quickly.Neeves, I have zero interest to restart the debate on this matter that was already done to death in Hurricane thread on his anchoring upgrade, but for the records, I can't recall anyone to have called your suggestion (let alone yourself!) stupid.
None of us moboers would even consider such ground tackle setup not because it's stupid, but because it's way OTT and unnecessary for most anchoring needs.
If Magnum would be planning to anchor in Antarctic storms, he would be buying a completely wrong boat altogether, to start with!![]()
