Magnum
RIP
Or, why not simple splice 2 short lengths of rope to a hook and secure everything on deck? ie hook is engaged just within bow roller stem. Easy to deploy, easy to remove.
The problem appears to be lack of space between the windlass and the end of the stem head roller. The Lewmar chain stopper is 148mm long.
If you have a look here and go to Gallery, 360 Tour, you can see the gap is quite tight. Need to find a solution somehow.
Looks like a nice unit. I assume you had the baseplate fabricated separately? Did you also add the roller/guide just forward of the chain stopper?FWIW I fitted the Quick chain stopper and that is a bit shorter at 130mm http://www.quicknauticalequipment.com/?lng=en&ms1=13&ms2=1&ms3=90&ms4=287&cs1=01&cs2=&mvp=610&stp=td
It is actually very simple and costs nothing: it's sufficient to use the mooring cleats (they are just outside the pic in my post #42, astern of the fairleads).And if you go the simple and cheap hook route - don't use the capstan as the strong point, it completely defeats the object as you still load the windlass. You need an independent strong point for the rope, which means it might not be simple. (nor cheap).
That said, I disagree that attaching a rope to the capstan (in the same way as shown in the above pic) still loads the windlass. I mean, the chain loads the windlass rotationally, while a bowline attached to the capstan doesn't - and mechanically, the difference is huge.
Any pure pulling load with no rotational load capable to destroy the whole windlass/capstan assembly would probably be enough to rip off also the cleats...!
By "on deck" snubber, do you mean mine in post #22 or Deleted User's in post #45?MapisM, do you think the direction of the load on the cleats is important? That is, via the fairleads or inboard as per the above suggested "on deck" snubber?
Agreed. The difference I had in mind is that rotational load affects not only the whole windlass assembly, but also its internal mechanisms (friction/brake/whatever, depending on the type of windlass).Mapism, can you go over the physics of your rotational versus non-rotational loads please ?
As I understand from winches on small sailing boats, the capstan and gypsy are on a single shaft, and loads on either or both are transmitted via the shaft bearings and then the body of the winch to the base plate. Provided the chain or rope goes through the anchor roller or down a hawse hole to a pocket, the loads to the deck are only taken by the baseplate/bolts unit and you can only have one linear vector for that load.
In principle, I would think it's easier to break some of those components, before ripping off the whole thing from the deck!
Though of course this depends on how each specific windlass is built and attached to the deck.
FWIW I noticed last year that my anchor windlass was moving slightly on its mountings and I had Andrea tighten everything up over the winter. I guess that was due to years of use as a strong point for setting the anchor and holding the chain. I have never liked the idea of using the windlass for that purpose. IMHO its just too important a component on a boat to risk in that way which is why I fitted the chain stopper this seasonA
