Halo
I am replacing my skin fittings and the new ones have an attachment to secure an earth/anode strap onto the backing washer. I have always attached my dzr fittings to an anode but does it make sense to do so on 316 ?
NoI am replacing my skin fittings and the new ones have an attachment to secure an earth/anode strap onto the backing washer. I have always attached my dzr fittings to an anode but does it make sense to do so on 316 ?
No
It is recommended these days that skin fittings should be made of a corrosion resistant material and not bonded to each other or to anodes. (That includes DZR.)
As Rogershaw says ensure that they are well sealed in.
Also seal the thread well between them and the seacock valves Loctite 577 thread sealant might be appropriate here as it will lock the valve in position as well as sealing the threads. It is said to be particularly suitable for stainless steel. Loctite 577 Thread Sealant - 50ml
I have a tube of sikaflex ready for the job. Do you think loctite 577 is a significantly better option versus this or PTFE tape for the threads ??
Nice idea !I in fact used Sikaflex to seal both the skin fitting into the hull and the fittings onto the threads.
I also fitted a TEE on top of the ball valve so if necessary I could remove the plug in the top of the tee then open the ball valve to rod through the ball valve/skin fitting. The inlet/outlet is attached to the side entry of the tee.
Sikaflex is a popular choice . I suggest a Loctite thread sealer and thread locker as an alternativeI have a tube of sikaflex ready for the job. Do you think loctite 577 is a significantly better option versus this or PTFE tape for the threads ??
I prefer PTFE tape. There is a lot of rubbish "misspoken" about it not being able to line up a valve and it been unsuitable for tapered threads.Do you think loctite 577 is a significantly better option versus this or PTFE tape for the threads ??
