Stained sails
I have stainds on my sails that look like rust - maybe they are. Ergo, rust stains!
Can anyone please advise on how to remove them?
Ray
KeithH
23 Sep 2002
W Sussex, UK
A solution of oxalic acid in water is very good for removing rust stains, as the first reply said. However, oxalic acid is rather toxic, so I would strongly recommend using rubber gloves, and ensuring that the solution is kept away from anywhere where it could be accidentally injested.
KeithH
Note that :
a) Non -removal of the stain ... if it has small particles of iron etc. embedded in will gradually cause a hole in the sail .... took me a while to realise that !!!!
b) I have never been able to remove the stains completely, and advise that all cleaners will go some way to solving it - but you MUST thouroughly wash and rinse the sail after ..... otherwise stitching / material will start to fall apart after a while.
Thanks for the advice.
How weak? I presume that I should just apply the solution and then rinse off immediately?
Ray
