Birdseye
Everything works, all the buttons and the tiller ram connected to it except for one thing. You can press both +1 and +10 together to get the pilot to tack the boat but in my case it will only work to starboard and not to port. The -1 and -10 buttons work OK in isolation but if pressed together, there is no tack.
I have opened up the unit and it is fine inside with no burnt compnents or corrosion / water etc. It works as well now its back togehter as it did befoe I opened it up.
I am left wondering whether this is a failure of the 4000+ itself or another issue. This is that I had to repair the masthead ananometer and I reassembled it 180 deg out of line so that it works with an alignment set up of +180. The obvious question is whether the pilot when tacking is affected by the wind or just the giro compass. It is not set to steer by the wind.
Ideas?
Ideas?
