Bergman
ATUs
Come in many shapes and sizes
There are manual ones - the cheaper option. Where you twiddle knobs and and watch the SWR meter - If you dont mind twiddling these are the cheapest and best.
Some are specific to a single type of transceiver. these are often linked by a data lead to the TRX and this gives a preset config to theATU - clever but almost always limited to amateur bands. Also may only give a narrow range of impedance matching - typically will only do any good if the antenna has 3:1 VSWR or better. These are usless for marine application.
Other automatic types - the most expensive - use a bit of the tuning signal to measure and correct the the VSWR over a wide range of both frequency and impedance.
Or
Why not have a go at making one.
Buy a cheap VSWR meter 2 biggish variable capacitors and a coil of copper wire an hours work with a soldering iron and there you are.
A good feeling using homebuilt gear, even simple stuff like an atu.
Or
