Split pin alternatives
Fin
9 Jan 2004
Southern UK
Are there any other options to using split pins on the rigging bottle screws? The bog standard ones are a pig to change the rig settings. On the grapevine I've heard that you can get some good, secure, quick release and back in again pins that have no chance of catching anything. Having checked all the usual websites I've come up blank, any ideas?
Fin.
doug748
1 Oct 2002
UK. South West.
A Swedish (or similar!) company do these things, but its my understanding that you need new bottle screws. The company is called .....Hassenfoolds??. I can't quite remember but they have placed ads in the yachting press recently. I will try to find a contact if you get stuck.
I have recently experimented with the type of split ring you find on a key ring. This is reusuable and does not snag sails or flesh, but it it surprisingly difficult to find a size that will fit easily.
Franklin
12 Jun 2001
Gibraltar
Using SS welding rod, bend two ends at 90º to form a [ shape. Pass short ends through holes you normally place split pins in and bend down. I find this much easier to place and remove than split pins.
doug748
1 Oct 2002
UK. South West.
Got it. Hasselfors - Rig Loc. UK distributor: Victory Marine Fittings Ltd, Swanwick Marina, Southampton, SO31 1ZL. Tel: 01489 570797
doug748
1 Oct 2002
UK. South West.
Re: Split pin
clio
22 Apr 2002
stainless steel wire rings sold by west marine or make them your selves as most of us do
Talbot
23 Aug 2003
Brighton, UK
I have the alternative that you are talking about. They were supplied as standard by my rigging man. They are basically the same as a key ring with one end bent into the centre of the ring thus making it easier to install. PM me if you want a contact number (Hayling Island, Hampshire)
isandell
1 Mar 2003
Re: Split pin
Hasselfors are available in two type, the original uses grub screws which bear against the body while the newer type uses grub screws and plastic locking blocks.
Sea Holly did have the originals and when we replaced the rigging we gote newer type. I dont think that they are any more expensive than split pin types. But of course if you not need to change the rigging screws, it would be an expensive option.
Ian
wiggy
13 Jun 2001
Portsmouth Harbour
why not do as some of the racers and use cable ties to link the bodies of two bottle screws so they can not rotate, its cheap and amazingly easy.
Egbod
7 Apr 2004
Essex
Have a look at SureClips on www.mitron.se?index.html Go to English then Turnbuckle locking for pictures of their stainless steel clips with locking pins. I got mine from Mailspeed of Burnham on Crouch- they had to be ordered. I was worried about losing them when I wanted to remove them and they might just spring off. I have secured them with an old shoe lace hat the pin pushe through.
Fin
9 Jan 2004
Southern UK
Fantastic, thanks for all the replies. The tie wrap idea is one that I have never heard of before and sounds like the simplest and cheapest option. Having also heard about the other options using things like circular split pins its amazing that they aren't used more widely.
Fin
