squidge
Probly a silly question but...Having purchased a split charging diode for my 2 batteries i could do with advise on wireing.It looks as though the + charging side goes to the central terminal on my isolation switch ( 1,2,both off). If i put the split charge diode before the isolation switch and connect it to both batteries do i then connect the + terminal of the diode to the + treminal of the iso switch ? Am i correct in thinking that the diode is like a non return valve and will not let the current bypass the iso switch ?My current set up is to manually set the iso switch to the battery i wish to charge/use.Thanks /forums/images/icons/crazy.gif
<hr width=100% size=1>
