roaringgirl
Currently, the genoa sheets are 16mm polyester braid-on-braid. They have eye splices in the end and are attached to the clew with soft-shackles (on this size of sheet and sail, using bowlines is frankly dangerous whenever the clew flaps during sail changes).
I have discovered that the eye-splice is too wide to fit through the jaws of the whisker-pole. On our looming ocean crossing, we will be spending weeks wing-on-wing so I need to solve this problem. My plan is to remove the eye-splices and then splice a metre of dyneema into the end of the sheet. My force calculations show that 6mm dyneema should be sufficient, and I have this on board. This will easily pass through the jaws of the pole and the transition from dyneema to polyester should not be nearly as bulky as the previous eye-splice. This will allow the pole to slide on the sheet all the way up to the clew without obstruction.
Is there a reason I haven't thought of why this solution would be a bad idea?
