rogerthebodger
As long as you use a bridle from the ends for any uphaul (or downhaul) the pole should only see compression forces and Euler's column formulae will give you an idea. My memory has diameter to the power 4 as a factor so doubling the diameter gives a 16x improvement to buckling ....... but it was so long ago!
But first the maximum compression forces need to be determined.
