dje67
My Beneteau 36cc has a Sparcraft Ocean vang fitted. Recently it has become very noisy (squeaks badly when adjusted, or constant creaking noise if the boom is wobbling from side-to-side with no sails up). Have tried cleaning all the external fittings and pulleys with no success. I think the noise is coming from inside the strut. The vang is a spring-loaded type (not gas cylinder) and it feels like the internal spring is rubbing against the aluminium tubing.
Has hanyone taken one of these apart? I think it just requires some rivets to be drilled out, but I’m a bit wary of just doing that without knowing how the spring assembly is constructed (don’t want to end up with the pressurised spring launching itself into space).
Once apart, does it go back together without too much swearing and loss of limbs…?!
What maintenance can be done internally?
The vang has a name-plate saying ‘Sparcraft, Ref. 000 326, 150kg’
Thanks, David.
Thanks, David.
