[167227]
Has anyone else noticed anything like this with their SPADE?
It seems like a shocking amount of slop.
I've been using mine full time since September and it's dragged once and has failed to set a good few times. To me, an anchor that can fall apart like this and have that much slop after less than a year of use is very poor. I havent given it a hard time, haven't seen any wind over 40 knots. I am always careful not to anchor on rock and always dive on it after its down.We have a Spade Anchor, 17years old. We anchor 5 months / years & apart from a bit of rust it’s fine.
Why don't you ask them what they think?Has anyone else noticed anything like this with their SPADE?
Your experience is very different to mine, I used a Spade for 6 years in the Med, Brittany and the Atlantic Iberian coast. It failed to set perhaps once and I cant remember it dragging, it held us in a 50+kt gust in Santa Ponca when a 'tornado' blew through. The shank isnt a tight fit in the base and that didnt create a problem.I've been using mine full time since September and it's dragged once and has failed to set a good few times. To me, an anchor that can fall apart like this and have that much slop after less than a year of use is very poor. I havent given it a hard time, haven't seen any wind over 40 knots. I am always careful not to anchor on rock and always dive on it after its down.
I have, a few months ago they said it's fine but it's getting worse. And Ive been waiting to hear back again since last weekend. I'm asking for other user experiences.... thanks for your help.Why don't you ask them what they think?
I drop 5:1, let the weight of the boat settle the chain out straight, then apply slow pressure in reverse until full throttle.Your experience is very different to mine, I used a Spade for 6 years in the Med, Brittany and the Atlantic Iberian coast. It failed to set perhaps once and I cant remember it dragging, it held us in a 50+kt gust in Santa Ponca when a 'tornado' blew through. The shank isnt a tight fit in the base and that didnt create a problem.
How do you drop and set your anchor ?
Ps. Is your shank this loose?Your experience is very different to mine, I used a Spade for 6 years in the Med, Brittany and the Atlantic Iberian coast. It failed to set perhaps once and I cant remember it dragging, it held us in a 50+kt gust in Santa Ponca when a 'tornado' blew through. The shank isnt a tight fit in the base and that didnt create a problem.
Will do later, its in use atmCan you post a picture of the underside of the blade so we can see the shank attachment.
Not now as i regalvanised it, prior to that perhaps not quite as loose but far from tightPs. Is your shank this loose?
Very different experience here, can't really fault it. Living on the hook 24/7. Will check for movement in the shank next the boat moves but it's on the (not very big) boat list of 'really good things I would buy again without question'.I've been using mine full time since September and it's dragged once and has failed to set a good few times. To me, an anchor that can fall apart like this and have that much slop after less than a year of use is very poor. I havent given it a hard time, haven't seen any wind over 40 knots. I am always careful not to anchor on rock and always dive on it after its down.
I hope this is the issue. Getting a replacement here will be a nightmareI would be looking at how tight the connection bolts are
Mine is similar. Tightening the connection bolt won't make any difference. I did replace the set screw that came with mine with a plain shank bolt. I think Spade claim the load is taken by the joint not by the bolt. I wouldn't worry about it.
Yep, pretty sure the bolt is non structural, just keeps the shank from pulling out of the slot, load is 90deg in different direction. Want to check mine now but it's a bit busy right now..Mine is similar. Tightening the connection bolt won't make any difference. I did replace the set screw that came with mine with a plain shank bolt. I think Spade claim the load is taken by the joint not by the bolt. I wouldn't worry about it.
