Javelin
I've recently fixed a Southerly that was t-boned whilst on her mooring, (see Dec edition PBO)
She is in very good condition and below is spotless.
Anyway i was just finishing off a few outstanding jobs on her before we took her out of the shed and whilst looking in the bilge below the saloon table I spotted what looked like a bit of soft wood.
To cut a long story short, all the sheaved plywood below the saloon raised area is rotten and it appears it has been for some time.
All the sections of plywood. though partially sheathed, touch each other which has led to the main chain plate bulkhead suffering the same fate.
The plywood inside the chainplate knee had turned to dust, the bolt holes in the backing plate which was made of aluminium, have elongated and I estimate the chain plate must of raised by at least 15mm.
Tomorrow I'll get the water tank out and check out the aft knee which is also sounding hollow and the transverse bulkhead under the galley.
I was very surprised to find this state of affairs in what otherwise is an immaculate example of this boat.
If you have a similar boat I urge you to check under the saloon floor and check as it appears that as all these sections of plywood touch, if any get wet, they will all be effected.
The grp tabbing they use is at least 4 inches high which is good in one way as it protects from water in the bilge but bad if the water does get in somehow the tabbing acts like a bucket holding the water in.
On the off chance has anyone taken the water tank out of one of these before?
Just wondering what joy I'm in for in the morning...........
