Source for s/s U channel (for 10mm washboards)?
Bertie1972
Active Member
16 May 2016
I'm trying to find stainless U channel to be used as guides for 10mm polycarbonate washboards.
No luck so far online - can anyone recommend a source of stainless channel in this size?
Thanks for the replies guys.
Duncan's & Lady in Bed's suggestions are 10mm OD, but the actual slot seems to be 8mm.
I'm thinking it might be easier to get 8mm poly since this size channel is easily found.
Although I described them as washboards in the post, the actual function is a board to prevent my Spaniels disappearing out of the stern (with suitable gap at the base for water exit).
I guess the narrower width (than an actual washboard) should mean 8mm will be sufficient?
