Sonic Boom?
cgull
30 May 2001
Oxford
Last Friday I was in mid channel and heard what I thought was a loud explosion nearby. Time was about 10.45 bst.
Could this have been Concordes sonic boom?
robp
Yes almost certainly. Do they still do trips out of Bournmouth? First time I heard it, I thought we were being used as target practice by a warship!
Normally two booms like a locker lid bouncing as it slams shut...
M
mikenda - delete
It is the French Concord . We hear it every day 20 miles inland nr Salisbury at the same time.
rich
7 Jun 2001
JERSEY
www.portofjersey.je
The first time I heard what I now realize was Concorde, I was in mid-channel on a 36ft stink-boat. When we heard the double bang it sounded as if the engines had blown themselves out the arse-end. Immediatetely shut down the engines, but un-noticed by me, one of the engines stalled and consequently the temp guage shot up to the red, so in diving down below, throwing all the furniture, fittings and carpet into the cock-pit in our panic to get to the engine compartment, and lifting up all the floors, with fire extinguishers in hands, we were a bit bemused to find, no smoke, no fire, and nothing obviously wrong.
After a lot of head-scratching by myself and the crew we put everything back in place undamaged, started everything up again, and everything was fine, and it wasn't until half an hour later we realized what the noise had been.
rich :))
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
We became quite used to hearing the British Concorde over West Wales as it went supersonic after clearing the coast. One time we heard only a single bang and discussed possible reasons for this for a short time. On entering Milford Haven we discovered that the bang was in fact a column at one of the refineries that had been struck by lightning the night before, burnt all night and then exploded.
alex_rogers
30 Aug 2002
Lymington
I was told that one of the first signs that you are approaching land from a west-to-east Atlantic crossing is the sound of Concorde breaking the sound barrier as it heads to New York. Unfortunately, Concorde was grounded whilst I did the crossing so I never found out whether this was true or not.
tome
28 Mar 2002
kprick
www.google.co.uk
First time I heard it was Solent to Cherbourg as we were passing close astern a Russian freighter. Scared the wits out of us, we were convinced they had opened fire and shook our fists at them.
Same thing happened on the way back, we all leapt on deck but no freighter. Then the penny dropped...
Apologies to the bemused crew of the freighter.
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
I always understood (allthough I'm quite possibly wrong) that the sonic boom is not just heard when the sound barrier is broken, but all the time the aircraft is supersonic.
If that's the case, then presumably Concorde drags a ba-boom footprint across the Atlantic several times a day. Vessels close enough to its flight path should hear it whether close to land or not.
Or am I wrong?
jimi
19 Dec 2001
St Neots
I understand it just to be when the aircaft actually goes supersonic. I regularly used to hear the distinctive BOOM BOOM when climbiing at Swanage. My climbing partner worked for BAE and explained what it was and how it happened.
Twister_Ken
31 May 2001
As I remember the physics, its all the time that a body is supersonic, because it is creating a pressure wave in front of itself which it then overtakes (ina continuous process). This causes an overpressure which is what we hear.
You can appreciate the effect if you've ever been in the butts on a rifle range. Rifle bullets are supersonic and produce a distinct 'crack' as they pass overhead, separate from the sound of the weapon which you hear a second or two later.
tome
28 Mar 2002
kprick
www.google.co.uk
It's all the time Concorde is supersonic, and the reason for the double boom is one from the leading and one from the trailing edge.
A mate who's a BA 747 captain told me that whilst the aircraft flies close to its cruising speed limit, the cockpit gets very noisy because the airflow over the raised bump of the cockpit gets very close to the speed of sound.
Rob_Webb
20 May 2002
Auckland
Re: Sonic Boom - Position Fixing!
Yes, it would have been Concorde as she turned left over the channel en route Paris-NY, and accelerated above mach 1. It's the right time too. For the record, when supersonic, the shock wave is very similar to that created by a boat moving through the water i.e. it creates a continuous bow wave and stern wave all the time is flies above mach 1 - hence the double-boom exactly like encountering the bow and stern wave of a vessel passing you by at sea. Also like meeting a ship at sea, the exact sound that you experience will vary according to your distance fromt the vessel, the angle at which you hit the wake, the speed it is travelling etc.
My father (now retired) was the supersonic aerodynamicist for Concorde during it's design and early trails so I'm well familiar with the world's observations on supersonic flights and the rights and wrongs of the sonice boom - essentially, it has long been resticted to flying over the ocean for this route and whilst sailing between Cherbourg-Solent you can find yourself under a thumping great double bang on the right day. The sound of the sonic boom varies with weather - a cloudy, wet day will dampen the sound to a thunder-like rumble, whilst a clear blue, warm, dry day with the bird directly in sight can produce a sharp crack, rather like a battleship loosing off some heavy rounds at you - quite alarming until you realise what's happened!
I have often joked to novice sailors on my boat that one can use the Concorde timetable in conjunction with a stopwatch and a sextant to confirm your position as she passes overhead - got to be quick though!
Rob
