That pin soldered joint next to it definitely needs reflowing!One of the resistors has blown. There's a small hole in it and it's open circuit. How do I tell what the resistance was. Are they identified by dimensions. There's another on the board which has the same dimensions.
A bit leaky but not abysmal. measure the other one for comparison.
It's because the circuit diagram has incandescent lamps as indicators, hence the symbol for the lamp itself. The actual panel has LEDs so they require series resistors to drop the voltage across them to something in the order of 2-3V, not the 12V for the normal lamps. It appears that each LED has two 620Ω in parallel giving a series resistance of 310Ω which is not untypical. If one of those failed then everything should still work but the affected indicator would glow less brightly than its mates........... I was just wondering why there are more components than shown on the circuit diagram........................................................
Sorry; brainfart time, that is actually broken. Double check of the other similar diode will confirm or deny.Yes you're right. 59k one way open circuit the other.
In the first instance I do find size is the easiest first step to identifying surface mount components, so a vernier caliper does become very important.One of the resistors has blown. There's a small hole in it and it's open circuit. How do I tell what the resistance was. Are they identified by dimensions. There's another on the board which has the same dimensions.
It the excitation resistor then ITYWF it'll be something in the range 33 to 50 ohms.It goes to the voltage sensing terminal labelled R on the alternator.
Both diodes are10k one way open circuit the other.
Yes that is indeed what it is but in this case it appears to be a self exciting alternator so the excitation resistor would only come into play if the residual magnetism in the alternator were to collapse. I had a Delco like that.It the excitation resistor then ITYWF it'll be something in the range 33 to 50 ohms.
The warning light goes out when the alternator is charging because it has then 12v on both sides so no circuit.I put 12v on the board today. The alarm circuits seem to be working OK. I haven't tested the charge light yet as I'm still not sure how it works. It's connected to the L and R terminals of the alternator. Presumably these have 12v when charging or maybe only when not charging. Can't quite see how this puts the warning light off. I'm sure someone out there can explain. Still unclear where the pop came from. The 3 amp fuse looked intact. It's one of those car fuses with a very clear indication. Just wondering if whilst fault finding I activated the stop solenoid which makes a similar sound.
Grounding the wire from the alternator with the ignition on, yes, it should. Running the engine then should put that wire to 12v because the alternator is producing 12v, and the light should then go out, no negative, just positive both sides.So grounding the charge connection on the panel should put the light on.
