Something went pop.
KAM
6 Jun 2005
I was fault finding the alarm panel on my Yanmar 3YM30. It's called an alarm panel because replacements cost €700. It looks like I've blown surface mount resistor. Anyone know how to identify these. I was just wondering why there are more components than shown on the circuit diagram. A new one is out of the question. Looks pretty simple to emulate. Does anyone manufacture a generic warning light buzzer panel or can anyone point me in the direction of a suitable circuit diagram.
penfold
25 Aug 2003
On the Clyde
I don't see any obvious smoke escape from that; where do you think has failed? The resistors are 620 ohms according to the marking. What's on the other side?
KAM
6 Jun 2005
I think it's the charge light circuit. There's only one. I accidentally shorted it to earth. The other side of the board is blank. I don't think it's a multilayer. I presume the components are to drive the LEDs from 12V. Replacement price is totally outrageous.
penfold
25 Aug 2003
On the Clyde
Left to right you have what I think are 3 transistors, two diodes, 4 LEDs and a capacitor, then 9 resistors. Which do you think has had the smoke escape? I can't see any gross signs of damage but the pic is a bit fuzzy.
KAM
6 Jun 2005
It must be something associated with the charge light circuit or maybe a couple of common components that drop down the 12v. I'll have a look under a magnifier. It was definitely a pop and the board is now not working. All's well with everything else.
penfold
25 Aug 2003
On the Clyde
In the extreme it's a very simple device; it could be replicated using stripboard. I'm assuming the 700 yoyos is for an entire control panel with ignition keyswitch, alarm, idiot lights, a tachometer and temperature gauge?
bedouin
I think those "transistors" are in fact diodes - not sure why they have three "connections" but you will see from the empty spaces that only two of the pins are connected
KAM
6 Jun 2005
Not sure what 700 yoyos are. It's only the charge light, over temp switch and oil pressure switch the 4th indicator is for water intrusion which is not connected. Totally baffled why the replacement costs so much.
KevinV
12 Oct 2021
These two spots might be worth a look - it looks like a hot wire may have shorted these - a scrape with a scalpel would sort this out.
  • Like
Reactions: KAM
Alex_Blackwood
19 May 2003
Fareham
Instead of all the speculation. It might be helpful if we knew what, exactly the OP was doing when it went "POP" What "test kit" where exactly he was using it and how. Then all the bits of info. that are unimportant and don't matter, but might just be the clue!
Depending on what he was using I suspect that it is unlikely that a resistor would blow, for example. That just about leaves the three diodes and the LEDs.
There is also another component, below right of the diodes, which I can't ID. Edit +2 others at the bottom of the board!
Boater Sam
14 Mar 2020
Philippines and Thailand
Instead of all the speculation. It might be helpful if we knew exactly the OP was doing when it went "POP" What "test kit" where exactly he was using it and how. Then all the bits of info. that are unimportant and don't matter, but might just be the clue!
One end of which must be attached to something on the reverse side of the board.
bedouin
Blown diodes would stop the buzzer sounding but not the lights coming on.
It is a very simple circuit with no common components - knowing which parts work and which parts don't would help isolate the problem. If nothing works it has to be a power supply problem
