Yellow Ballad
Well it was probably their hull when they did it but after washing my hull off after my winter haul out I noticed a screw through the GRP just infront of the log wheel.
A can't see the screw from the inside as there's a glassed in battery tray above the area but I can feel the screw thread underneath penetrating through the grp (infact I can feel two there's another a few inches behind (you can just make it out in the picture)). It's not screwed into a backing pad just straight through the glass (under the water line)! I have no idea what it's for, someones suggested a "weed" deflector for the log, I though possibly a hull anode as the batteries are above it? Either way it's not doing anything and I'm a little uncomfortable having a couple of screws through the GRP (even though they must have been there for the last 30 years as the previous owner is just as surprised to see them as I was). They must have had gelcoat over the top of the head as the previous owned has taken the bottom back to gel twice in his ownership and has never seen them.
What's your thoughts?
I can either plug them with thickened exoxy and flocoat over the top. I assume that's what it was like before and I dislodged the plug cleaning the hull.
Do the above but cut the battery tray out (I'm planning on relocating the batteries anyway) and glass over the top of the threads as a backup.
But I still have two random screws sticking through my hull.
Or remove them and bevel inside and out then glass the holes The head is only about 10mm across so will I need to make the bevel larger then normal?
Or listen to the PBO collective.
All suggestions and advice listened to..
Tom
Tom
