Some more bits and bobs...
syvictoria
12 Oct 2009
Europe
Some further bits and bobs for sale. All prices are excluding cost of P&P, or can be collected from Norwich (NR2), or PE31 by arrangement:
USED Bronze water strainer, 1/2" BSP, ~140mm x ~55mm, plus old fittings as pictured - £20
Bulgin connectors, 2 x 2 pin plugs, 1 x 2 pin socket, 1 x 3 pin plug & 2 x dust caps, one plug has been fitted and removed, otherwise all are NEW/UNUSED - £20 the lot or make me an offer!
AS NEW 25mm 4.25m jackstay webbings in blue - £15 for pair
AS NEW Cutless bearing for 25mm shaft, tube dia 34mm, all rubber with flange at end - £8
USED 6 x white (ish!) Majoni Star size 2 fenders. All hold air, but three are currently partially deflated as that's how they were stored in a locker most recently - £25 for all 6
USED Heavy duty galvanised boat hook head (no pole) - £10
USED Small galvanised Danforth-type anchor. Approx. 58cm long and 4.8kg - £10
USED Life buoy light (no batteries) and bracket - £5
AS NEW Battery cable off-cuts, black 16mm2 7.5m untinned, red unmarked (~16mm2 or possibly slightly lighter) ~2.5m untinned - £10
AS NEW 25mm s/s prop shaft off-cut, 40cm long - £10
AS NEW Air filter, IIRC replaces Beta Marine part 211 - 62950 up to MARCH 2011 3 CLAMP TYPE, up to 35hp - £10
USED Chalwyn hurricane lamp glass - £5
Book, The Canal Du Midi : A Cruisers Guide (paperback in VGC) - £5
Book, Black Sailed Traders: The Keels and Wherries of Norfolk and Suffolk, Roy Clark (hardback) - £5
USED ASUS laptop bag (I can provide measurements if anyone's interested in it) - £10
MANN-FILTER fuel PU 723 - £2
Delphi diesel fuel filter HDF296 complete with gaskets - £2
Racor seal kit F11-1413 (no filter, seal only) - £2
USED Forespar Marelon 2in valve plus elbow and thru hull - £10
USED Forespar Marelon 1 x 3/4in & 1 x 1in-3/4in valve (or thereabouts) plus a selection of USED plastic elbows, thru hulls, etc. as pictured. PLEASE NOTE: These are all very likely imperial/US threaded. Offered ONLY for re-use ABOVE THE WATERLINE or for some other NON-ESSENTIAL use so as to avoid them going to landfill!!! All move freely. £ FREE barring P&P
DVDs Ellen MacArthur: Fastest Solo Sailor Around The World, The Official Record Breaking Story & The Ellen MacArthur Story Part 1 1998 - 2004, £10 each or £15 the pair
AS NEW Genuine TECNOSEAL zinc tear drop bolt-on anode, 2.1kg with slotted holes, part no HC200. Measures 200mm between the hole centres - £30
AS NEW Seaflow plastic vented anti-siphon loop for 19mm hose, Part No: 507619 - £3
AS NEW Bronze 3/4" BSP 90 deg elbow, ECS 49112/PK - £3
SH VHF radio bracket (I can provide measurements if required) - £5
Please ask if you require any further photos for any reason!
syvictoria
12 Oct 2009
Europe
Sale pending for Bulgin connectors, cutless bearing, battery cable off-cuts, Beta air filter, Delphi diesel filter & all Forespar Marelon valves.
syvictoria
12 Oct 2009
Europe
Sale no longer pending (reason unknown).
All items therefore remain available! I'm open to sensible offers, particularly on multiple items.
syvictoria
12 Oct 2009
Europe
Canal du Midi, Black Sailed Traders & 2in Marelon valve now sold.
Bulgin connectors, 16mm2 cables, anti-syphon loop and life buoy light/bracket now also sold.
