RogerMayne
The reason that you should use crimp connection as opposed to solder on battery leads is due to the possibility of heat under load melting the solder
There should be no need to use both methods if you've done one or other correctly. If you've done a bad crimp then bad soldering isn't going to help.I'd go for a reasonably good crimp, with a minimum of solder.
And having had one "production car" in which a little bit of resistance in each of the crimped terminals added up through eight of them to enough to making starting on winter mornings with a battery past its initial youth difficult and having had to solder them all are the reasons I like soldered fittings.You will never find soldered battery cables on a production car, boat, truck etc. You will find crimped terminals
qualified to work on RN battleships,QUOTE]
When did the RN last have a battleship?
HMS Victory!
Crimping off a length is a well know RN occopation!
Well if you're going to get technical they were Type 22 frigates and Type 42 destroyers! It was a long, long time ago. Most of the wiring I had anything to do with (mainly instrumentation systems) was interconnected using ceramic 'chock blocks' which would shatter into a million pieces if you used the wrong sized screwdriver.
My tuppence worth.
However for battery cables, I prefer to use tube type terminals and solder, covered with heat shrink to help keep moisture out of the joint.
QUOTE]
So long as the joint is correctly soldered IE total penetration of the joint which the average tyro might find hard to achieve then not only does the heat shrink keep out the moisture,but if 3 or 4 layers are used of varying lengths from about L = 10*D L = 6*d with longest on the wire and tapering down to shortest outside, then this softens the joint and reduces the effect of the stress raising edge by spreading the bending over a longer length. This is especially important on the lugs attaced to the engine/gearbox and starter where there is sometimes a lot of movement especially with Yanmars when idling.
I must admit this is how I did all the battery cables and power cables on a Hunter Channel 32 built by a friend which was given a lifetime guarantee in about 2000 and we never found any problems with any of these joints including the negative and positive mounted on the engine when giving them their annual inspection. However I would not recommend anyone unfamiliar with soldering to attempt these joints without an afternoons practice as getting it right first time will be more a matter of luck than skill and the reason I was asked was because the friend had tried and been dissatisfied with the results of his handiwork.
It is important that the components are clean and correctly fluxed, that they are at the right temperature when the solder is applied and that no more solder is used than to fill the lug otherwise it wicks up the cable.
Always finish with at least a single layer of shrink sleeving over the lug and wire.
A solder iron is totally unsuitable for battery lead connections. You need to use a gas torch such as those supplied with disposable bottles around 500cc
size. The knack as was said earlier is to stop applying heat as the cup starts to fill so that the heat in the lug cup and wire is used to melt the remaining solder as it is applied. Too long an application of heat results in the whole assembly possibly being too hot as finished and the solder wicking up the wire.
The lug needs to be nipped in a vice by the drilled end and the wire held as still as possible to ensure a perfect soldered joint.
Once again....only if you are really satisfied with your practice attempts then proceed. Oh yes.....do not practice in the kitchen as hot solder does not improve the lino or wood floor
It is much easier to solder the wee yellow red and blue terminals however quite unnecessary if a ratchet crimping tool is used.
