Gazza
Am now working my way through our newly acquired boat, and have discovered a solar powered vent above the galley.
There is a small solar panel powering a fan - no battery as far as I can see, so clearly for daytime use only. However, the round plastic cover that screws over the solar panel, while being clear all around the edge, is opaque in the centre, which is, of course, directly over the solar panel. The fan works without the cover on, but stops immediately the cover is placed over it. There is no obvious way to remove the opaque part, and nothing to replace it with anyway.
The unit has the letters ECS moulded into the casing, but otherwise no clues as to origin, and local enquiries haven't helped. Can anyone shed any light (no pun intended) on this?
Thanks.
Thanks.
