Cactus Sailing
i must be of that age... i can't get my head around it.
i just want a semi flexible panel to fit on my coachroof and a solar power regulator to charge my batteries, its not to live off the power while on board so i dont need nothing big, just to maintain charge on the batteries without setting anything on fire or overcharging etc.
Specs; i have 120ah of leisure battery on board in 2x60ah if that makes a difference, again im just looking for something to top up the batteries, nothing is left running while not on board so i was thinking a 10w panel?
i do sail alot (as posed to motoring) so use power for instruments - i only tend to use the fridge on shore power or while on engine, other than that i switch it off and treat it like a cool box, i often charge up on shore power / motoring back in which has been adequate throughout summer, winter months my batteries are not at optimum charge so it will shorten their life i expect, i suspect its because im only motoring and sailing and not stopping on the boat overnight plugged in and using more than re-charging? unless my batteries are just on their way out.
i'd rather steer clear of eBay and the raft of cheap tat so any recommended "kits" from reputable places would be welcome
alternatively could i just put a small panel under a hatch? is that a thing, will it charge through a window?
thanks
thanks
