Prima
N/A
More than helpful. Thank you ever so much for taking the time to repost them. It's given me a very good idea now of how they might look on mine
Definitely interesting. Do you know which direction gives you the best charge rate? I assume due south, but I really am a complete spanner when it comes to things like this so forgive what may seem a silly questionThen there is the swinging around - it is noticeable that the panels work best when facing directly into the sun.
And, of course, they don't work as well on cloudy days.
But maybe looking at the History display, gives a good indication of the success of this project.
Anyway, it is now back to enjoying being at anchor.
I hope you find this interesting - I do.
Hi Mike
If the State of Charge (SOC) for your batteries does not go below 75% first thing in the morning I suspect you will find the batteries will last a lot longer than you have experienced in the past.
Please do let us know what the SOC is at the end of today (7.00pm).
I would suggest this has been a total success given that after a week away from the Marina you can see the SOC at 100%, totally achievable in the past.
Graham
Hurricane, one curiosity if you don't mind a small o/t: have you ever actually used that loudhailer which you've got behind the horns?
I've got what appears to be the same bit of kit on the DP (connected to a Raymarine 430 unit), but I can't see myself ever using it, and I'm thinking to get rid of it altogether.
Together with the sat dome, but that's another story - and each to their own on that...![]()
Aha, all understood.The loudhailer is connected to...
But technical differences aside, you actually didn't answer my question...
What I was wondering is if you (or anyone else, for that matter!) have actually ever used that bit of kit.
I just can't see myself shouting at S while maneuvering, without risking some retaliation when it's dinner time!
Besides, in a situation where shouting at someone would be necessary for some reason, I would think that using voice right away is easier and faster than grabbing the microphone, possibly pushing some buttons, or whatever...
It's not like the distance from the helm to anywhere onboard is anywhere near a cruise ship, after all!
You stated;
"When I switched on the generator, the batteries started charging at 100amps - after 2 hours, they were only taking 25 amps (and this is the point - to finish charging, the generator would have to run for the rest of the day)".
What was the SOC when you turned off the Genset when it was only charging at 25 amps?
agree with GSL,
Mike, try for a day or two to NOT run the genny at all (or switch off the bat charger if you just need 220V for cooking or whatever)
If as GSL says you get 100% SOC by 17:00, then you're absolutely fine!
Considering your genny produces far more power than needed for cooking and/or charging, you could use the rest of that power on a watermaker.
If you want a decent 80-120lt/h piece of kit, they come with a 3Hp el.motor. Not sure it's worth getting a 24V one, just get a decent 220V and use it when you run the genny. An hour a day or two can produce enough water to avoid going to a port for as long as you wish.
My 2X300W panels are going to be fitted midweek, I've got a 100/30 victron mppt and I'll order the blutooth thingie tomorrow. Would be interesting to check and compare (although I'm on lower loads being much smaller altogether and I hope I can avoid running the genny fullstop)
cheers
V.
Also, the Victron MPPT Solar controller thinks it is Bulk charging all the time because the boat is drawing a load from it.
Definitely not an option.
The whole idea was based on getting the fastest part of the charge from the battery charger when it was able to put the most in.
And leave the solar panels to "finish off"
The solar panels would never be able to keep pace with our load on their own.
And some of it is about convenience.
Last night we ran the generator for a couple of hours to watch some "catch up" TV
This morning the SOC was 81%
So, today is starting off more charged than yesterday.
