VicS
Which panel do you think the misprint applies to?
The 24 volt one you gave the ebay number for
No way is 29.2 the correct OC volts for a 24 volt panel
best bet would be to feed it into an MPPT regulator then to charge the 24v battery...
If you connect 2x 80 watt panels in series to produce 24 volts, you will have an 80 watt input at 24 volts,
I am a bit unhappy with fitting a 24 volt regulator to a 12 volt panel, which I seem to understand from your last post.
You have two distingt posibilities.
Firstly charge the batteries at 12 volts using a changeover switch, or relay. That means you charge the 12 volt batteries, and then link them in series to make a 24 volt system. You have to be very careful to use a special changeover circuit, because of the current draw when starting engines etc, which will fry everything in sight if you get it wrong.
I have a 24 volt bow thruster, and use this system.
The alternative is to connect 2 panels in series to give 24 volt charging, and a Voc of nearly 40 volts, and a typical actual charge at battery Vpm of about 28 volts via a charge controller.
If you connect 2x 80 watt panels in series to produce 24 volts, you will have an 80 watt input at 24 volts, so a max of 6.3 amps, which should be enough for most installations. (My single 80 watt 12v panel does 640 amp hours of battery banks with no problem) .
My current panel came off Ebay in January at £149, so two off would cost about the same as your panel, which got me thinking about putting an array on my kitchen roof.
Thanks again for all input, so choice now seems to be, 1x 80w panel + Sol-1 mppt regulator, or 2x80w panels in series with simple PWM regulator.
My house bank is 24v 360ah, for and against???
I do like the idea of the MPPT as it is claimed to be more effective in dull [winter] conditions...
True.Er I dont think that is right.
2x 12 volt 80watt panels in series will give you 160 watts at 24 volts
2 X 12 volt 80 watt panels in parallel will give you 160 watts at 12 volts.
OK thanks all, both panels will be flat on coachroof side by side, no shadows, so it seem like it will be 2 x 80w 12v panels in series with simple reg.
